Tharcisio Souza Posted August 1, 2023 Posted August 1, 2023 I'm trying to check whick titl will be better for my Photovoltaic plant. When I use the Optimization Tool to do so, PVSyst just shows the message "The Scan was aborted by the user" when the progress bar reaches the end. It's important to note that no request was made for the procedure to abort and I tryed it many times with many different projects. My software is at version 7.4. The last time I tryed using this feature it was as version 7.3.1 and it worked perfectly. Does anyone have a clue of what could be wrong? Best regards.
Solaranger Posted March 18, 2024 Posted March 18, 2024 I also faced the same issue, have you figured out why?
Michele Oliosi Posted March 18, 2024 Posted March 18, 2024 Hello, we will fix this issue in version 7.4.6, out within a couple of weeks (normally).
