Sunoor Posted August 1, 2023 Posted August 1, 2023 Hi, I am conducting research on PVsyst performance on different Meteo datasets. I selected a very simple Solar PV array with zero degree tilt. I downloaded the meteorological data from NSRDB for year Houston 2020 with 30 min temporal resolution. I uploaded the data through the PVsyst custom file method. It suggested me a -14 min shift. So I performed two simulations: i) Simulation with Time shift ii) Simulation without timeshift. I am not able to understand why does PVsyst model produce difference in Annual GHI, Energy Yield and PR? Without Timeshift With Time Shift (-14min) Annual GHI 1800 kWh/m2 1702 kWh/m2 PR 89.43% 88.64% Annual Energy 17381 kWh 16Test_Houston_Project.VC0- WITHOUT Timeshift.pdfTest_Houston_Project.VC1-WITH Timeshift.pdf290 kWh Simulation Variant VC0 VC1 The most surprising result for me is the annual GHI, since PV array was at the zero degree tilt, the amount of annual GHI shall not be different in the timeshifted case. Regards
Caroline F. Posted August 9, 2023 Posted August 9, 2023 Hi, i have some similar results. it would be interesting why these parameters change
