I want to compare the performance of various photovoltaic (PV) technologies is examined using the PVSyst thermal model. The PV technologies under consideration include monocrystalline silicon, polycrystalline silicon, amorphous silicon, microcrystalline, and cadmium telluride. The following parameters will be considered in the simulation: i) Module efficiency ii) Temperature coefficient of maximal power iii) STC Rated Output (Wp) in watts. May I know how to modify those parameters in PVsyst. Many thanks.
These parameters are basic specifications of each PV module. You can change them within the PV module (using the PV module definition dialog).
Then you have to save this PV module as a new PAN file for using it in your simulations.
