kjs55 Posted June 24, 2023 Posted June 24, 2023 I suggest changing the default option of "AC losses power reference" in Project Settings from "PNomPV(ac) at STC" to the more physics-correct "PNom (inverters)". Thanks. I'm running PVsyst v7.3.
jacob Posted January 11, 2024 Posted January 11, 2024 Thanks for the recommendation. Do you know how to chart or plot PNom(Inv)? It is not completely clear to me if this is a static variable or if the simulation varies the power used in the ohmic calculations based on AC generation at each hour in the simulation. Do you have any insight? thanks,
Ajay Deepak Posted February 1, 2024 Posted February 1, 2024 AC loss with Pnom is accurate as it is considered Inverter power for percentage loss calculation. Example case: Inverter Power is 200kW, and DC power connected to the inverter is 250kWp. AC loss at STC level = 1.5% of 250kWp which is wrong and loss values will be lesser. AC loss at Pnorm (Inverter) = 1.5% of 200kW which is correct and loss values will be slightly higher than the previous case. Regards, Ajay.
