As part of a PV project with an 89 kWp optimizer, I'd like to study the difference in production between a solution with 2x33.3 kW inverters (SE66.6K) versus 3x33.3 kW inverters (which is currently ordered).
But I don't manage to simulate the production with 3x33.3 kW inverters. PVSyst don't let me oversize the installation, but it will be done in reality...
So that's important that i get this simulation in order to prove that 2 inverters is better than 3.
I note that I don't have the option of adding an inverter manually in the string configuration, as specified in the help file. Nor limiting the number of strings solutionate the problem:
Thank you for your help,
Sylvain Vitali
Yes, it is quite possible to define your situation.
When  right-clicking on the inverter's list, you have the opportunity of adding an inverter. Then, click "Reinitialize" and "Adjust subarrays" and everything should be OK.
NB: This possibility is mentioned in the help.
  • 3 weeks later...
Bonjour et merci,
Même avec votre commentaire, j'ai mis un peu de temps à trouver. Il faut vraiment connaitre cette option pour l'utiliser!
Il est vrai que dans l'aide, il est écrit  "(right-click on the sub-array ComboBoxes)"
Personnellement, je ne comprends pas ce qu'est un "sub-array comboboxes", je trouverais plus clair de dire de "clic droit sur le nom d'un des onduleurs" ou comme vous l'avez dit "right-clicking on the inverter's list".
Bon après-midi,
Sylvain Vitali
