shri Posted May 25, 2023 Posted May 25, 2023 Hello, Is Pvsyst working on any features to estimate subhourly clipping? I've read a previous research paper Pvsyst published on a method to estimate using sub hourly data sets. Is this method something you are working on incorporating into the software and do you have a general timeframe of when it would be available?
Michele Oliosi Posted May 26, 2023 Posted May 26, 2023 Hi ! Thanks for the interest in this feature. Yes we are working on implementing that in PVsyst ! We will be trying to release it this year, but it's not possible to be more specific at the moment.
kjs55 Posted July 26, 2023 Posted July 26, 2023 Hello, I'd like to see VDE Americas' & Tim Townsend's Triple-C model incorporated into PVsyst. Upwards of 20% of the USA solar PV market is financed using CCC as the solution for accurate modeling of subhourly clipping. It's simple and straightforward to implement in PVsyst with several key advantages over the method PVsyst published at WCPEC-8 in Sept. 2022. Here's a recent, related LinkedIn post, and a new white paper is available upon request and will soon be posted (likely also on LinkedIn) after which I'll follow up and post it on this thread: https://www.linkedin.com/feed/update/urn:li:activity:7087861833511960576/ The v1 model was initially published at PVPMC 2022: https://pvpmc.sandia.gov/download/4415/ The model's now at a stable v5 with many more, high quality, ground-measured 1-min. datasets added to the mix.
kjs55 Posted August 16, 2023 Posted August 16, 2023 P.S. I forgot to include the title of the poster (PVPMC link above) which I'm adding now partly for my own future copy/paste benefit: The Triple-C Method for Correctly Simulating PV Clipping Loss by Townsend & Sauer et al.
kjs55 Posted December 7, 2023 Posted December 7, 2023 The Triple-C ("CCC") white paper is now available at the following URL: https://www.linkedin.com/posts/tim-townsend-93a4a711_triple-c-a-subhourly-clipping-correction-activity-7138341773319331840-kNWO/ The authors, and many other major PV industry stakeholders, would like PVsyst SA to please directly incorporate this specific modeling option into the PVsyst software program as soon as possible. Thank you.
kjs55 Posted December 7, 2023 Posted December 7, 2023 P.S. I forgot to include the title of the newly published CCC white paper by Townsend and Sauer: Full title: Triple-C: Clouds, Capacity, and Clipping A Method to Correct Traditional Hourly-Based PV Simulations to Account for Subhourly Clipping Loss Short title: Triple-C: A Subhourly Clipping Correction for PV Modeling
Sergio Táboas Posted February 7, 2024 Posted February 7, 2024 On 5/26/2023 at 8:51 AM, Michele Oliosi said: Hi ! Thanks for the interest in this feature. Yes we are working on implementing that in PVsyst ! We will be trying to release it this year, but it's not possible to be more specific at the moment. Hello Michele! There is any update about this? Do you plan to implement it somewhen this year?
Michele Oliosi Posted February 8, 2024 Posted February 8, 2024 23 hours ago, Sergio Táboas said: Hello Michele! There is any update about this? Do you plan to implement it somewhen this year? Development of version 8 took longer than expected. Indeed, this time “This year” should be a more trustworthy statement.
Marcello86 Posted February 8, 2024 Posted February 8, 2024 6 hours ago, Michele Oliosi said: Development of version 8 took longer than expected. Indeed, this time “This year” should be a more trustworthy statement. I am also looking forward to it.
kjs55 Posted June 7, 2024 Posted June 7, 2024 Spatial Smoothing is the newly released supplement to Triple-C. CCC-modeled clipping losses can be reduced by 1% per annum with Spatial Smoothing with a sufficiently large PV array size. See proceedings of Sandia PVPMC 2024: Spatial Smoothing Reduces PV Clipping! by Tim Townsend <https://pvpmc.sandia.gov/download/7908>. Please implement CCC+SS immediately in PVsyst.
