Debbie Posted May 19, 2023 Posted May 19, 2023 Hi PVsyst team, In version 7.3.4, when I input a non-unity power factor, I am still getting 0 reactive energy in the loss diagram. Is this possibly a bug? Screen captures below taken from the same report. Also, in this same model, even though I chose a custom reference tracker for the diffuse calculation, it spent a long time (~8 minutes) calculating the diffuse integrals when running the model. I look forward to your response. Thank you.
André Mermoud Posted May 22, 2023 Posted May 22, 2023 Please carefully check that your inverter is able to deliver reactive power (in the inverter definition: page "Output parameters", frame "Power factor"). NB: By mistake in the version 7.3.4, the limit is the higher CosPhi between Lagging and Leading. You should define a same limit for both. This will be corrected in the version 7.4.
Debbie Posted May 22, 2023 Author Posted May 22, 2023 Thank you, I had to modify the inverter file, it was limited to only unity power factor. I was not expecting that when using this new inverter file.
