Salvo Posted May 4, 2023 Posted May 4, 2023 Hi everyone, Is it possible to design the plant layout after having imported the topographic data directly into PVsyst, or is it better to do this preliminary operation in another software and then import the pvc file? Thanks in advance Regards
dtarin Posted May 4, 2023 Posted May 4, 2023 Detailed design should be done outside of PVsyst. If you need something high-level or indicative, PVsyst can work, but it is better to use a software intended for PV design.
furkann71 Posted May 4, 2023 Posted May 4, 2023 hello, after transferring the topography of the land to pvsyst with csv, how do I place the panel on the land?
furkann71 Posted May 4, 2023 Posted May 4, 2023 Do I make a correct assessment by transferring the topography of the land to pvsyst with csv and then positioning and simulating it in pvsyt? Or are there any other steps I need to take to make an accurate production estimate?
furkann71 Posted May 4, 2023 Posted May 4, 2023 Also, after importing the topography with csv, can I import the land image, how can I do it to pvsyst?
Stéphane Posted May 5, 2023 Posted May 5, 2023 Hi, To place the panels on the land you have several options, like creating them manually from the PVsyst menu, creating a zone and filling it with PV fields or importing the panels from another software. Once everything is set up properly you can run the simulation. If you want to import a ground image you can follow these help sections: https://www.pvsyst.com/help/index.html?ground_image.htm https://www.pvsyst.com/help/index.html?ground_image_control.htm https://www.pvsyst.com/help/index.html?ground_image_control_usage.htm I hope this helps. Regards, Stéphane
furkann71 Posted May 7, 2023 Posted May 7, 2023 Hi, When the 3D Shadow Scene screen opens, you will see several tools loaded in the upper right corner of the program. By clicking on the "Shadow Properties" button, you can set the intensity, color, visibility, etc. of the shadows. You can open a menu to set its variables. where is this i couldn't find it??
Stéphane Posted May 8, 2023 Posted May 8, 2023 Hi, When you open the 3D scene you can see on the right the list of objects that are in the scene. You can double click on an object to open its details: In the detailed view of an object you can adjust the settings about the shadows casting of this object : You can watch the following 2 videos to learn more details about how to draw buildings and objects in the 3D scene: https://www.youtube.com/watch?v=qJ0P7szS_jo https://www.youtube.com/watch?v=Ey4CIKcY0F8 I hope this helps. Regards, Stéphane
furkann71 Posted May 10, 2023 Posted May 10, 2023 Hello, I do a panel layout on the terrain I imported with csv and then I use the automatic altitude feature, but some panels still seem to be embedded in the terrain. how can i solve this
