kamomeno68 Posted September 30, 2013 Posted September 30, 2013 I've run into a problem with a module PAN created for Ver.6 not being compatible with Ver.5 - is this true? Are the PAN files created for ver.6 not compatible with ver.5?
André Mermoud Posted October 1, 2013 Posted October 1, 2013 Yes. As the PAN files of the version 6 hold additional parameters, these cannot be "recognized" by the reading procedure of the previous versions 5. But files of the version 5 can be read in the version 6 of course. This is a general rule in PVsyst: if a file format is modified in a given version (usually for adding parameters or data), it cannot be read by older versions anymore. Allowing a general reading with older versions would imply that we update all older versions, which is absurd. This is what is named "upwards compatibility".
