After updating PVSyst today i have found the following bugs:
  • in Shading scene, zone editing, while adjusting any of the Azimuth, Pitch, Tables Spacing or Distance from ground will set the same input value to the other ones listed here
  • in System, while selecting the modules,thr Manufacturer <year> column, the years go up to 2034 for example. I was trying to select Trina Solar 665 W module. PLease have a look.
This last one has no impct, but the first one really affects the functionality and should be addressed immediately
Hi @iulian.trisca,
Regarding your 2 points:
  1. This only happens if you haven't created any zones yet. This problem is also present in previous version. We will fix this for the next patch.
  2. This is a display issue specific to Trimax Solar PV modules, it is also present in previous version. We will fix this for the next patch.
Thanks for bringing these issues to our attention.
Regards,
Stéphane M.
