Detroit Solar Posted March 8, 2023 Posted March 8, 2023 Hello all, As the title states: What is the difference between Grid lim. Pnom Ratio and Pnom Ratio? My assumption is the What is the difference between Grid lim. Pnom Ratio is the DC (Modules) ratio to the AC limit of the inverter. The Pnom is the AC overbuild of the inverter. To simplify, if your POI limit is 500 and you have 550AC of inverters. Thanks
Detroit Solar Posted March 9, 2023 Author Posted March 9, 2023 thank you for the response. I did not finish my thought regarding that question. That will teach me to be on a conference call and attempt to write something. Then the Grid lim. Pnom Ratio is the DC overbuild at the inverter: If your inverter is 500kw and you have 650kw of modules then your Grid lim. Pnom Ratio would be: 1.3. Thank you again for your help
Detroit Solar Posted March 9, 2023 Author Posted March 9, 2023 On 3/8/2023 at 4:01 PM, dtarin said: That is correct. Thank you. thank you for the response. I did not finish my thought regarding that question. That will teach me to be on a conference call and attempt to write something. Then the Grid lim. Pnom Ratio is the DC overbuild at the inverter: If your inverter is 500kw and you have 650kw of modules then your Grid lim. Pnom Ratio would be: 1.3. Thank you again for your help
dtarin Posted March 9, 2023 Posted March 9, 2023 Example: 700kWdc, 650kW inverter nameplate @ Pnom, 600kW grid limit Pnom ratio = DC capacity/Inverter Pnom: 700/650 Grid limit Pnom ratio = DC capacity/Grid limit: 700/600 Generally, the grid limit is less than the inverter nameplate, so the DC/AC ratio is higher here. In the PVsyst report, the Grid lim. Pnom ratio is found under System Summary, and the Pnom ratio is found under PV Array Characteristics.
