Hello all,
I am having trouble explaining why is this happening. The graph is just going off the charts. Any ideas, what may I be doing wrong?
Thank you in advance!
Hi this peak is due to the clipping, indeed any power above the grid limitation or inverter nominal power will be clipped to the value, the generation distribution is therefore biased towards values close to the clipping value. There is therefore probably nothing wrong with your system.
However at the moment the scaling of the plots is automatic in PVsyst, and there seems to be a bug on that level. At the moment there is nothing that can be done to change the scale of plots when printed in the report, unfortunately. We'll be looking into how to improve this situation...
