PRtemp calculation according to final report and hourly csv file
jonipa
Recently I've been checking the results on PRtemp that PVSyst throws, based on the calculation they give in https://www.pvsyst.com/help/performance_ratio.htm which is indeed the one given by NREL and IEC 61724-1.
Below the results for a yearly TArrayAver= 40,79ºC. You can see the reults given by PVSyst and, in red, the ones manually calculated using the formulas mentioned above:
Date Month TArray GlobInc E_Grid PR PR PR PR temp
        °C kWh/m²/mth MWh/mth ratio temp ratio
01/01/1990 1 18,829 98,151 4592,1 0,900 0,850 0,900 0,857
01/02/1990 2 22,082 124,36 5801,4 0,897 0,859 0,897 0,864
01/03/1990 3 26,722 176,88 8113,6 0,882 0,860 0,882 0,862
01/04/1990 4 30,465 216,64 9692,9 0,860 0,848 0,860 0,851
01/05/1990 5 37,29 270,47 11559 0,822 0,830 0,822 0,831
01/06/1990 6 42,159 292,54 12333 0,811 0,832 0,811 0,834
01/07/1990 7 47,381 321,19 13209 0,791 0,825 0,791 0,828
01/08/1990 8 47,486 288,4 12333 0,822 0,854 0,822 0,861
01/09/1990 9 40,079 212,27 9308,6 0,843 0,858 0,843 0,861
01/10/1990 10 32,068 154,07 6954,4 0,868 0,858 0,868 0,863
01/11/1990 11 23,085 103,25 4766,7 0,888 0,852 0,888 0,857
01/12/1990 12 18,789 88,653 4127,8 0,895 0,847 0,895 0,853
Yearly total   33,785 2346,9 102791 0,842 0,845 0,842 0,842
Does any one know how PVSyst calculates the PRtemp values? Seems like they are not using the formulas described in their manual.
Thank you!
Thank you André,
Been checking my calculations and i am much convinced that they are correct. Yet, still don´t know why I obtain a different value for the PRtemp, must be then something odd with some value considered.
Had done it using the hourly csv exported from the advanced simulation option.
Thank you anyways
