Nitin Posted January 23, 2023 Share Posted January 23, 2023 Dear Team, I am trying to simulate PVsyst with dual axis tracker system. I have selected "Tracking Two Axis " in Orientation and create shading scene for the same. But, when i was considered Bifacial modules and update Bifacial factors for the same. it has showing error as attached sniping shot. Kindly help us with this. We need to understand the settings to simulate Dual Axis Tracker system with bifacial modules. Regards, Nitin +91-9860648978 Link to comment Share on other sites More sharing options...
Michele Oliosi Posted January 23, 2023 Share Posted January 23, 2023 Hi, There are two issues: Most importantly, the bifacial model can only work with horizontal single-NS-axis trackers or slightly tilted axis. It won't work with dual-axis trackers. This is a current limitation of PVsyst. A minor issue is the one shown on the message. When opening System > Bifacial system, you will see the following radio buttons You should select "unlimited sheds 2D-model" for fixed plane orientations, and "unlimited trackers 2D-model" for tracker orientations. Link to comment Share on other sites More sharing options...
Nitin Posted January 25, 2023 Author Share Posted January 25, 2023 Thanks for your support ? Link to comment Share on other sites More sharing options...
