Tharcisio Souza Posted December 12, 2022 Share Posted December 12, 2022 I've ran two simulations, both of them are a 3MW (12 x 250kW inverters) and 4,066MWp array, two different sites. The first simulation, let's call it Plant 1, I got the value of -4,06% Inverter loss due to nominal inverter power. The second plant, Plant 2, with the same inverter and array configuration, I got the value of only -1,82% loss. Plant 1 Plant 2 When I spotted this difference I figured it could be due to the respective plant sites, which are distinct. So I inverted the sites in both simulations, but it didn't make much of a difference: It's noticeable that the inverter temperature loss changes properly, but the inverter loss duo to nominal inv. power is about the same. Plant 1 - Inverted site Plant 2 - Inverted site I can't figure out what exactly is causing this Inv. loss duo to nom. inv. power, but it's certainly about each simulation's parameter. Can somebody help me with this issue? What parameter could be causing this significant difference? Link to comment Share on other sites More sharing options...
dtarin Posted December 12, 2022 Share Posted December 12, 2022 (edited) Same OND files? Is one using MPPT share and the other not? Post screenshots from System menu showing the arrays for each. Edited December 12, 2022 by dtarin Link to comment Share on other sites More sharing options...
Tharcisio Souza Posted December 13, 2022 Author Share Posted December 13, 2022 13 hours ago, dtarin said: Same OND files? Is one using MPPT share and the other not? Post screenshots from System menu showing the arrays for each. Plant 1 Array Plant 2 Array It's the same array configuration, with the same inverters. I remember using Plant 1 as the basis of Plant 2 by saving as another project. Then I just modified the plant site and 3D scene since the rest would be the same. Link to comment Share on other sites More sharing options...
Ajay Deepak Posted January 4, 2023 Share Posted January 4, 2023 Please check grid power limit settings. This may be different. Link to comment Share on other sites More sharing options...
HLubke Posted February 4, 2023 Share Posted February 4, 2023 Hi Tharcisio your first site has ~3.6% higher irradiation and soiling losses are different too. Also, Ajay's comment is valid. In the system all losses are balanced so that reducing on loss may cause another bottleneck to gain relevance and inclrease losses at another point. Link to comment Share on other sites More sharing options...
