Matthais Posted November 29, 2022 Share Posted November 29, 2022 Hi guys, I dont know if its a problem that i cause or if its a bug, but look at this: 1. I cant choose the Sungrow 110CX Inverter that has 110kW. It automaticaly changes when i try to save to the 100kW Sungrow inverter that is also called 110CX? 2. When i want to build PV-arrays, the number of inverter starts with 1 but then when i add more subfields it goes 2.1, 3.2, 4.3 and so on... Can someone help me? Link to comment Share on other sites More sharing options...
dtarin Posted November 30, 2022 Share Posted November 30, 2022 For 2 , you’re not adding inverters, you’re adding mppt inputs, which are fractions of an inverter. Uncheck that box to add whole inverters , or add the total number of mppt inputs to get one full inverter. You have 9 inputs, so 9 = 1 inverter Link to comment Share on other sites More sharing options...
Matthais Posted November 30, 2022 Author Share Posted November 30, 2022 But that is what i did or not? As you can see on the picture: 9 MPPT Inputs chosen -> for an Inverter that has 9 MPPTs => 1 Inverter. This Inverter now is supposed to get 2 Strings on every MPPT-Input. => 18 Strings per Inverter. That configuration is now 1 Inverter. Then i want to have several of these Inverters -> i add subarrays. Finally as you can see on the right side i have several inverters, each one with 9 MPPT on which 18 Strings are combined. Why is my Number of inverters 8.7? Isnt every Subarray l(ike the ones i created) 1 Inverter? Link to comment Share on other sites More sharing options...
dtarin Posted November 30, 2022 Share Posted November 30, 2022 The screenshot does not show all subarrays. Are all with 9 inputs? Link to comment Share on other sites More sharing options...
dtarin Posted November 30, 2022 Share Posted November 30, 2022 For #1, we don't see the details on the OND file, but if you're using the PVsyst default and it is the same as shown here, then at unity power factor, you should be producing 110kW per inverter (run a simulation, check max inverter output in the excel hourly output file). The OND file shows 100kVA nominal, 110kVA max. Link to comment Share on other sites More sharing options...
Matthais Posted December 7, 2022 Author Share Posted December 7, 2022 On 11/30/2022 at 7:30 PM, dtarin said: The screenshot does not show all subarrays. Are all with 9 inputs? Yes all are with 9 Inputs. The OND looks the same as yours that you shared. The Problem is: There are two SG110-CX Inverter that i can choose -> picture 1 and I want to choose the one highlighted. So i click on the one i want, but the programm doesnt accept that i chose this one. You can see in picture 2 that i chose the 110kW version with operating voltage 200-850V, but the operating voltage and other info shown (highlighted) is still the one from the Inverter that i didnt choose. So i am not able to choose the Inverter i want. Next time i close and open the window, the 100kW (that u can see in picture 1) is chosen again. Is there an explaination for this? picture 1 picture 2 Link to comment Share on other sites More sharing options...
