kjs55 Posted November 15, 2022 Posted November 15, 2022 I just set a Grid power limitation such that the Hidden Parameter "High Grid Power limitation Power Ratio" set point value is exceeded. I was able to run a simulation with no errors/warnings/error messages/warning messages. I did not test whether the Hidden Parameter "Low Grid Power limitation Power Ratio" is also ignored.
André Mermoud Posted November 17, 2022 Posted November 17, 2022 These values in the hidden parameters ("Low/High Grid Power limitation Power Ratio") are only used for the verification of your definitions (warning messages). The PNom ratio mentioned on the dialog is the ratio of your grid limitation specification, and the PV installed power. It is shown just for information.
