IB31 Posted September 23, 2022 Posted September 23, 2022 Hi , How can we optimize the mutual shading effect in single axis with vertical axis configuration in the absence of backtracking strategy.
Michele Oliosi Posted September 23, 2022 Posted September 23, 2022 Optimizing this type of system means changing the pitch / tilt / size of the tables. You can use the batch mode or the optimization tool (found in advanced simulation) to run multiple variants and find the optimum one. If you want to do so, in the 3D scene the tables should all be in the same array of trackers (grouped as one array, not individual trackers) ! Btw which type of vertical axis do you have in mind? Single axis shared by all tables (i.e. a large rotating surface, e.g. floating) Each table has an individual axis. Do the tables have a tilt ?
IB31 Posted September 27, 2022 Author Posted September 27, 2022 Thank you very much for the response. My configuration is second option i,e each table with individual axis along with some fixed tilt.
