azein Posted August 30, 2013 Posted August 30, 2013 When I try to choose "Detailed according to module layout" for simulation in the Near Shading definition, an empty "warning" message appears. Please help
André Mermoud Posted September 11, 2013 Posted September 11, 2013 This option of electrical shading calculation is only useable when you fully define the "Module layout" parameters. If you have not done this, the message is indeed empty by mistake. I have filled it for the next version 6.12.
siamon Posted September 19, 2013 Posted September 19, 2013 (edited) I am experiencing a problem when I am trying to complete the Module Layout section. I label the tables under the "Comment" field in the 3D structure section. When I go to the Module Layout section, after clicking "Get From 3D Shadings" the drop-down menu still does not reflect the correct table names. In fact, the same table names are repeated up to 3 times in the drop-down list.http://en.wikipedia.org/wiki/ISC Edited July 21, 2014 by siamon
André Mermoud Posted September 21, 2013 Posted September 21, 2013 I have fixed this problem for the version 6.12, to be released on 23/06/13
