azein Posted August 30, 2013 Posted August 30, 2013 On a different set of projects I tried, I'm always having an empty "warning" message when I try to tick the "Detailed, According to Module Layou" in the Near Shading panel.I tried simple 3D designs with no success.I reinstalled PVsyst on another machine and still the same problem. i'm using V. 6.08Any suggestions?
André Mermoud Posted September 6, 2013 Posted September 6, 2013 This option is to be used when you define a "Module Layout" configuration. If such a configuration is not defined, there is nothing to calculate, and this option should not be activated. It is indeed a mistake in the present version, I will manage for desabling this option.
