stefm Posted August 29, 2013 Posted August 29, 2013 Hi,I upgraded to the newest version of PVsyst (6.11) and could not find a parameter that could previously be written to the simulation output file. Incident angle used to be a parameter in the "Incident energy factors" category. Has it been removed from the output file parameter list, and if so, is there an alternative parameter from which I can easily calculate the incident angle? For reference, this was with a tilted single axis tracking system with a tilt angle of 0 degrees, with a defined shading scene. Thank you!
André Mermoud Posted September 6, 2013 Posted September 6, 2013 It has perhaps been removed by mistake, I don't know. I will reintroduce it for a next version.
