Hi all,
I was trying to check Default for shunt resistance, but the small check showed at the right side, not inside the box.
Did I set up the default successfully?
Sorry, I don't identify the apparition of this fleeting little mark. It is probably a Windows artefact that I have never noticed.
But this has nothing to do with the indication that this case is checked or not, which appears as a blue-background check mark.
However it is indeed not always possible to get the default value of Rshunt  (depending on the other parameters, especially Rserie).  And this is not really necessary, often a higher value (1000 ohm or more)  is more suitable as it increases the RSMax value. See the help (little blue questionmark).
