Wenshuo Zhang Posted August 29, 2022 Posted August 29, 2022 Hello, Can we use PVsyst to simulate 2P mounting system? Do we just double "Coll. band width"? Are there more parameters need to be changed? Appreciate if anyone could shed light on. Best regards, Wenshuo
dtarin Posted August 29, 2022 Posted August 29, 2022 Yes. Yes, along with setting the correct pitch and height from ground. You also have the option to define a center gap if the tracker has one.
Wenshuo Zhang Posted November 18, 2022 Author Posted November 18, 2022 On 8/30/2022 at 12:02 AM, dtarin said: Yes. Yes, along with setting the correct pitch and height from ground. You also have the option to define a center gap if the tracker has one. Thank you!
