dtarin Posted August 27, 2022 Posted August 27, 2022 (edited) Hello, A couple of suggestions/requests here: Add relative humidity as an output variable in the 8760 Allow extruded polygon height to be edited from the equipment list Edited August 27, 2022 by dtarin
Bruno Wittmer Posted September 1, 2022 Posted September 1, 2022 Concerning 1: Relative humidity and the precipitable water column, are variables that are only used in PVsyst when the FirstSolar spectral correction model is activated. If this is the case, they will be available as output variables: Concerning 2: I am not sure if I really understood the suggestion. If you double-click on an extruded polygon, either in the drawing or in the object list, you can edit the height:
dtarin Posted September 1, 2022 Author Posted September 1, 2022 For the extruded polygon, it is allowing the edit of heights when multiple polygons are selected. For example, when opening the equipment list, the properties of the polygons cannot be edited. It would be great to allow height to be edited in this field.
