Hi
I am working on battery sizing and for that i was trying to upload load profile.
But when i upload the file it gives error "Data not yet defined".  i checked file format but did not find way to solve this
Below is screenshot, please tell if anyone knows
The required format for the importing of hourly parameters in PVsyst  is the following:
  • Text file (CSV format with commas or semicolons) written in ANSI  (not UTF8)
  • All lines beginning with the hash symbol '#' are assumed to be comments, and will be ignored
  • Blank lines are ignored
  • The first line that does not start with #, holds the column titles. The first two columns should be "Date", and "P Load", further columns are ignored
  • The following line contains the units of the data in the columns. The date should have no units, the units for the load can be power ([W], [kW] or [MW]) or energy ([Wh], [kWh] or [MWh])
  • Then there follow the lines with the values, one line per data entry
  • The date and time in the first column can be given either in European format (DD/MM/YY hh:mm) or in US format (MM/DD/YY hh:mm)
  • The file should contain all hours of a generic year (from  01/01 at 00:00 up to 31/12 at 23:00). Only day and month will be retained, the year will be ignored
  • These dates/hours do not need to be related to the dates of your input meteo file: they are for each hour of a generic year
If you are blocked, you can send us your excel file to support@pvsyst.com in order to look at it and help you.
