EA2EQD Posted June 23, 2022 Posted June 23, 2022 Hello, I have a doubt regarding how can influence the TMY weather data from two different sources (meteonorm & solargis) on the gain (GHI/POA), I think this must be only geometrical matter. I have run the same model with both databases: v.7.2.16 TMY MN yields a PR of 79.2% and the ratio GHI/POA = 1.29 v.7.2.16 TMY SGis yields a PR of 78.5% and the ratio GHI/POA = 1.27 also, as a reference I have the original version: v.6.53 TMY MN yields a PR of 78.2% and the ratio GHI/POA = 1.29.
Michele Oliosi Posted June 24, 2022 Posted June 24, 2022 The conversion GHI / POA is not only geometrical, in that you have to decompose into different irradiance components: direct, diffuse, circumsolar, and so on. Each of these components will be transposed differently. Please read: https://www.pvsyst.com/help/models_meteo_transposition.htm Therefore, depending on the diffuse/global ratio, the transposition will yield different results.
