BYES_DEV Posted June 1, 2022 Posted June 1, 2022 Hello, I would like to know the procedure to use the optimization tool to know the best azimuth and inclination, in the framework of E/W structure for ground power plant? Because this tool is only available to me if I am in "unlimited sheds". Thank you in advance. Thank you in advance, Arnaud.P Bouygues énergies et services - Montpellier
Bruno Wittmer Posted June 2, 2022 Posted June 2, 2022 For ground mounted E-W structures, which are called 'domes' in PVsyst, you can currently only change the pitch in the 'Optimization Tool' (as well as in the batch mode). We will add the possibility to change also tilt and azimuth in one of the upcoming releases, a corresponding ticket has been added to our development pipeline. There is no precise timeline yet for when this feature will be available.
