Raffaele Posted April 28, 2022 Posted April 28, 2022 Hi everyone, I need to make a comparison between two configurations of the same plant: trackers vs dome structures. I wonder if there is a simple way to "convert" the 3D scene from trackers to dome structures using PVsyst, otherwise I should draw again the whole layout using PVcase. Thanks in advance
Stéphane Metz Posted April 29, 2022 Posted April 29, 2022 Hi Raffaele, Unfortunately this is not possible. There is a way to change followers to single PV tables, but not in dome structures: Transform tracker to object: Then transform object to PV faces: I don't know if this will help you ?♂️
