With the GCR = Sensitive area / Ground occupation area, is there a way to know the value of the ground occupation area?
For example, if I have an "Unlimited sheds" system, in the "Orientation" options, the value of GCR is given, but it would be nice to have an estimate of the actual ground occupied. So that I can adjust my Pitch parameter and number of sheds and keep an eye on the ground occupied, to see if I'm more or less within the area I'm given.
Thanks
No sorry, this is not explicitly mentioned in this dialog.
You have to take the the PV area from your "System" definition, and simply calculate this value explicitly  by yourself  (Ground area = Sensitive PV area / GCR)
We will see for adding this information in a next version.
