shubham Posted April 2, 2022 Posted April 2, 2022 Hello PVsyst I'm looking to simulate BIPV (building integrated photovoltaic), is it possible to simulate it using PVsyst. Here BIPV means, I need cover building face or facade with PV Module at 90°. If yes, then how can I do it ?
Michele Oliosi Posted April 4, 2022 Posted April 4, 2022 Hi shubham, Yes you can do this. You can use the "multiple orientations" option in the "orientation" window, which lets you use up to 8 fixed tilt orientations. Then you can just choose a tilt value = 90° when you need it.
shubham Posted April 11, 2022 Author Posted April 11, 2022 Hello @Michele Oliosi Thanks for your support, I tried to simulate multiple project as you described in your response. At one place I got stuck, when I click on "Detailed electrical calculation". After choosing this setting, I have freedom to make my own string in "Module Layout". But I can't able to do it, if I make more than 4 (four) row of module as shown in image. I can't able to see all the tables at same time or one by one. Do you have any solution regarding this problem. Please help
Michele Oliosi Posted April 25, 2022 Posted April 25, 2022 Hi, There seems to be a bug in the window that we need to address, we will raise a ticket on this. In the meantime the only option would be to use the automatic filling tool "Auto attribution". As long as the lower (the ones you can see) are correct, you can assume that the others are filled along the same pattern. An example below:
Michele Oliosi Posted April 26, 2022 Posted April 26, 2022 The correction should come out in the next or in two patches time.
