Laura Albarrán Posted March 22, 2022 Posted March 22, 2022 Nosotros estamos desarrollando una simulación con la versión 7.2.12 en lugares de Venezuela, Siempre se obtiene la alarma de error que se muestra en el archivo adjunto. Agradezco su apoyo para esta solución, mucho gracias, L.Albarrán
Adrien Villoz Posted March 23, 2022 Posted March 23, 2022 Dear User, I can't reproduce your problem for these coordinates. There seems to be a problem with your windows system: Meteonorm requires both the latest .NET runtime and latest VC++ Redistributable from Microsoft. You can try to reinstall PVsyst and make sure to install both prerequisites: .NET runtime and VC++ redistributable. Without those prerequisites, Meteonorm cannot work correctly. Alternatively, you can install them manually: Microsoft Visual C++ Redistributable for Visual Studio 2022 (both x86 and x64) from https://visualstudio.microsoft.com/downloads/ at the bottom of the page in “Other Tools, Frameworks, and Redistributables”. Make sure to install them with administrator rights. .NET 6.0 runtime from https://dotnet.microsoft.com/download choose the “Run desktop apps”, again both x86 and x64. Install them with administrator rights also. After reinstalling, make sure to reboot your system before trying in PVsyst.
