Krishnan Posted March 22, 2022 Posted March 22, 2022 In PVsyst, is it possible to model the east west bifacial PV systems? When I try to model the 3D scene and come to the bifacial tab, I see only possibility of unlimited sheds and trackerrs, but cannot use bifacial option for several orientations. So if I had to see the energy yield and performance of the system, I had to model the east and west side of the system separately and then correlate the results? Would be happy to know your feedback on this.
Michele Oliosi Posted March 22, 2022 Posted March 22, 2022 Hi, Yes unfortunately at the moment it is not possible to use the bifacial model with several orientations. One way would be to do as you write i.e. split the system in two and join both results. However, this will likely overestimate the backside production : e.g. the East tables will cause shadings that impact the backface of the West tables, and vice versa. These won't be taken into account when proceeding in this way.
Michele Oliosi Posted August 19, 2022 Posted August 19, 2022 You could sum the production hour by hour. Of course this is assuming string inverters. If you have inverters which share both orientations that is more complicated, you shoul still join the results step by step, and correct for effects such as clipping.
