MatiasSebBravo Posted March 22, 2022 Posted March 22, 2022 (edited) I cannot simulate tracker's 3D scenes built with AutoCAD and plugings like PVCase or VirtuoSolar. With fix structure I was able to solve it by changing the tolerance in the "shading scene construction > tools > orientation management". Most of the scenes I am building are placed in sites where irregular terrain characteristics having NS tilted trackers with tilt angles from -8Dgr to 8Dgr is very common. In my projects computing 3Dscenes under this scenarios is a must specially because I need to use bifacial modules. PVSyst 7.2.12 Screen shoots How can I process this type of 3D scenes ? What I am doing wrong ? Thanks and regards M Edited March 22, 2022 by MatiasSebBravo
Makarevicvhm Posted June 20, 2022 Posted June 20, 2022 (edited) On 3/22/2022 at 11:48 AM, MatiasSebBravo said: Hi, try to use this one, and put your axis +/-8degrees for the Max tilt axis for Bifacial 2D model Edited June 20, 2022 by Makarevicvhm
