We are trying to do batch simulation of tracker. But, When we select simulation parameters and simulate the PVsyst to get batch mode parameter file. We will get .CSV file but not with proper size and output. File will generate with only 1kB size.
Please suggest
  • 1 month later...
The "[...]BatchParams[...].CSV" file is not the simulation output, but will contain the parameters to be varied and the different simulation runs. As such it is a very small file.
You have to fill it with the values for the variables to be varied.
Once you then press simulation (in the advanced simulation window) the batch run will commence. At the end you will have a file named "[...]BatchResults[...].CSV"
You can also send us the file at support@pvsyst.com, if you think the file is wrong.
