I just upgraded to version 7.2.11 and now it appears that I am no longer able to modify the Axis Tilt of multiple trackers. Previously when I had multiple objects/trackers selected I could click on the "Modify Selected Objects" option and a small window would pop up allowing me to edit attributes of all selected items. However, with this new version, using the "Modify Selected Objects" option results in the "List and Management of Objects" window to open. It seems like it allows you to edit the Axis Tilt, however if the Plane Tilt remains unchanged (and Plane Tilt) is not an editable field.
Can you please advise on a solution here?
