Problem grid system definition, gives red error code not frequent between variants
Hi PV-syst,
I am working on a project where I tried to copy a variant of a system and I come across a problem. When putting the difinitions in System on my last sub-array there is a red code error like so in the picture.
On the other picture is the old variant seen which still works fine with exactly the seem proporties. The only thing I changed is 180 degree turned the model because this was the only thing still needing to be done. Now I can't continue and it looks like some sort of a bug.
This all happend after I did an update with PV-syst to the newest version. I would like some help with this. Many thanks in advance.
Greetings.
