As you can see from the technical datasheet of the inverter, the output power at 250KVA is given at 30 ° C and the output power at 225 KVA is given at 40 ° C.
A profile of the maximum AC power as a function of the temperature can be defined in the "output parameters" tab of the inverter.
The components supplied by the manufacturer are verified so the data is consistent.
Please check in your "CUSTOM" OND file that the maximum power parameter has been modified
Typically it's best to use the latest manufacturer OND file where possible, and as previously stated, check it against the datasheet. Although less common compared modules, a third-party verified OND file would be most preferable.
