Hi there,
I use medium voltage transformers on my simulations and I don't click the "night disconnect" option. Also I don't delete the inverter night consumption on the .OND file. I assume that the yield report I generate includes then night consumption.
If I click the "night disconnect" option for the transformer and delete the night consumption of the inverter on the .OND file, is it that sufficient to get accurate results or are there other loads at night time that cannot be "disconnect" manually on PVsyst?
I was wondering if someone could advise what is the most accurate way to calculate night consumption. Is there any method to follow to calculate this properly?
Many thanks in advance.
