EmmaVanoverschelde Posted August 11, 2021 Posted August 11, 2021 Hello everybody,I would like to use my own measured data as a meteo file. I am working with bifacial panels and i was wondering wich parameters u need to make a costum meteo file?Thanks in advance,Emma
dtarin Posted August 11, 2021 Posted August 11, 2021 GHI, DHI, ambient temperature, wind speed, or POA irradiance (GlPMeas in the custom meteo menu), ambient temperature, wind speed
EmmaVanoverschelde Posted August 11, 2021 Author Posted August 11, 2021 GHI, DHI, ambient temperature, wind speed, or POA irradiance (GlPMeas in the custom meteo menu), ambient temperature, wind speed But because i am using bifacial panels, I have PAO at the rear and front side, how do i implement this? Also I was wondering if it is possible to costum a meteo file with only 1 month worth of measured data?
dtarin Posted August 12, 2021 Posted August 12, 2021 But because i am using bifacial panels, I have PAO at the rear and front side, how do i implement this? Import front side irradiance as POA in PVsyst. I do not believe it is possible to import rear-side irradiance. To achieve the best results, it is best to import measured GHI and measured DHI. For a vertical bifacial system if you have GHI (with or without DHI), it will be better than POA. I do not think PVsyst can properly calculate GHI and DHI if using POA from a vertical bifacial system (a PVsyst admin should comment here). Also I was wondering if it is possible to costum a meteo file with only 1 month worth of measured data? Yes
