sairam Posted July 10, 2013 Posted July 10, 2013 Dear sir,i need to calculate solar pv sizing for motive load other than pumps.how to calculate sizing of pv plant considering the motor kw rating only.for example if i need to run 10 kw motor through solar pv only , how to size the solar capacity, i.e. how to compensate motor starting current in PV Design.i have not found any solution for this in any design literature.Regards,sairam
André Mermoud Posted July 10, 2013 Posted July 10, 2013 You cannot build a system without a battery, as the sun's production is never guaranteed. Therefore the problem will be reduced to define a stand-alone system. Your problem will be to find an inverter able to drive you motor, including the starting current. This is probably standard in the industry.
