Inverter Loss due to Voltage thershold ( i.e. when the array mpp voltage is below VmppMin).
I have run the simulation in PVsyst version 7.1. with Renesola 335 Wp and TMIEC 2.5 MW Inverter for a project. I am getting an Inverter Loss due to Voltage thershold as -8.44%. However my array Vmpp is greater than Inverter Vmin. I have run the same project with same design in PVsyst version 6.84 in which loss dur to Voltage thershhold is 0.00%.
What is the reason behind the changes?
Could you please clarify the same ASAP.
I have mailed the project files to support@pvsyst.com
  • 6 months later...
Are you sure that your number of modules in series and in parallel are identical?
For more information on inverter sizing please read:https://www.pvsyst.com/help/inverter_array_sizing.htm?zoom_highlightsub=inverter+array+sizing
