EA2EQD Posted May 30, 2021 Posted May 30, 2021 Good afternoon to all, this is my first post on this forum.Last week I had a problem simulating a contractual year custom meteo file (from 10 of Apr.19 to 10 of Apr20), whose weather values cover 13 calendar months, although it is actually 366 calendar days. When I ran the model a few weeks ago (in version 7.1.8) I had no problem, but when I ran it last week in version 7.2.2 the 13th output (corresponding to the last 10 days of the year to be simulated) showed a yearly subtotal instead of the monthly subtotal.At first I thought it could be a configuration issue, but I was checking all settings and i didn't found anything... then we simulated again in an older version (v.7.1.8) and we got the expected result.What could be the cause of this problem?Thanks in advance :)
Lazare Fesnien Posted May 31, 2021 Posted May 31, 2021 Hello, Can you send us on the following email address your request with your project and screenshots?support@pvsyst.com
Lazare Fesnien Posted June 3, 2021 Posted June 3, 2021 Hello, Thank you for pointing this out. This is a bug that we will correct for version 7.2.4. This only affects the display of the results, but the yearly results are unchanged.
