error massage
Hello sir
I do a simulation of the site that existed in the reality and the message that I get it is ( the array of Voc at -10 C is greater than the inverter absolute maximum input voltage )
could someone help me to get the solution to this problem, please
thank you before
-10C is the default minimum site temperature defined in project settings. This needs to be set per your specific location. If -10C is your site minimum temperature, then you need to adjust your string length so your Voc voltage does not exceed the voltage rating of your inverter.
