Tritone Posted May 4, 2021 Posted May 4, 2021 Hi,I'm having some problems with the partition in module chains with my trackers.I define the correct partition for a single tracker, then I want to apply this partition to other table of the same size.What I get is that the selected tracker receive the defined partition, while all other tables receive a different partition. Which is the problem? Am I doing something wrong?
André Mermoud Posted February 8, 2022 Posted February 8, 2022 Are the other tables exactly of the same size ? Did you push the button "Applica" ?
