MarVF6 Posted April 30, 2021 Posted April 30, 2021 Hello,I have a question to the shading losses of unlimited tracking systems in reference to unlimited sheds. "Backtracking" and "Irradiance optimization" is activated. To compare the shading losses I created a table with the losses of both simulations. fixed tilt tracking systemGlobHor 990,2 990,2GlobInc 1091 1231BeamInc 522,3 630DifSInc 400,4 398,6Alb_Inc 2,535 11,71ShdLoss 9,306 22,58ShdBLss 1,624 0ShdDLss 4,792 11,36ShdALss 2,43 11,22I'm wondering about the higher total ShdLoss with the tracking system. It makes sense that the Shd albedo losses are in total higher due to the higer albedo incidence irradiation and that the shading beam losses are zero because of the backtracking. But what is the reason of the higher shading diffuse loss? I try to understand the simulation for a better validation of the results. I'm thankful if you could help me. Best regards,Jan
kjs55 Posted February 24, 2023 Posted February 24, 2023 Hello, I happened to see this post and discussed it with a colleague and we have a few initial Qs: 1. What's the GCR in both cases (fixed tilt and tracking)? 2. What's the tilt angle of the fixed tilt PV system? 3. What's the tracker rotation limit (for the tracking PV system)? Thanks.
