Hello, does anyone knows how can i fill Zone in near shading with array of domes, for now i cant just fill it with simple PV Table in one direction.
thanks in advance
Construct two identical zones, one in E direction, one in W direction. Populate, then relocate the modules from one zone next to the other.
  • 5 months later...
is there a way to copy and paste a zone and to mirror it? I have a complexe zone. Because of that I cant create it two times identically.
thanks in advance
Create the zone and populate the modules in one direction, unclick the zone icon, select all of the modules, copy them, then paste next to the existing modules, press control + G to change their tilt/azimuth at same time to orient them to new direction. See
Your table length/partition should be defined based on your string size as close as possible.
