sergio Posted March 9, 2021 Posted March 9, 2021 I have imported a 3D scene (.pvc) carried out with PVCase. The solar field has 372 trackers and the 3D scene imported is been scomposed in 372 objects named ''tracking field #xxx''. I had thought that what I did was all right to launch the calculation of the shading scene with the option linear shadings.I was a little bit surprised when PVsyst shown me the following alert: ''The backtracking strategy is based on distance and width of trackers. Therefore you should define at least one subfield with several trackers. Please correct the shading scene.'' My question is: why PVsyst ask me to define at least one subfield with several trackers when all these informations are defined in the imported 3D scene of all the PV field (orientation, dimension, pitch, quantity of the trackers).Based on the above, what is the correct procedure to carrried out the calculation of the linear shadings? Thanks in advanceSergio
dtarin Posted March 9, 2021 Posted March 9, 2021 The trackers imported with PVcase are single, individual tables. PVsyst requires a set of tables to be present in the shade scene. If you select a table in your existing shade scene and open the options, you will see there is one tracker row. If you set the number of trackers to 2, you will be able to utilize backtracking. Make note that when importing from PVcase, if your trackers are at different slopes in the N-S direction, you may run into errors, especially if trying to model bifacial.
