Hi there,
Can someone explain how to simulate trackers using the 3D scene importing a .PVC file? Do they need to have the same characteristics? I mean pitch, axis tilt angle, etc?
I face some difficulties when calculating.
Thanks!
  • 3 weeks later...
You should be able to import trackers on a sloped terrain if you are using PVsyst 7.1.
Make sure you update to 7.1.2 as we found out some special cases in which it was not possible to proceed to the simulation, and these have been fixed in this patch.
