shahaf Posted November 20, 2020 Posted November 20, 2020 Hello ,If i have several orientation with different size of strings length - Could I make the inverter as multimppt and power each orientation to a specific mppt???In this case if i would put the same type of inverter to each sub array that combine on this multimppt inverter?? THX ALOT!!!
Lazare Fesnien Posted February 9, 2022 Posted February 9, 2022 Hi,When you have a different number of strings on the MPPT inputs, you should create one sub-array for each configuration (for example one sub-array for the MPPTs with a single string, and another one for the MPPTs with two strings). Then, in ‘power sharing’, you tell PVsyst which sub-arrays belong to the same inverter and how the power of the inputs is balanced.
