iqbal11 Posted July 6, 2020 Posted July 6, 2020 Hi!I found problem when I trying to save .pan files from PVsyst 7 to older version using saving mode option. After I click save somehow there is a warning box appear said that there was a read error from newly created pan files. Hence the file can't be opened
André Mermoud Posted August 10, 2020 Posted August 10, 2020 We are indeed preparing a way of saving PAN and OND files in a format compatible with old versions. However in the mean time, for reading a file of V 7 in the versions >= 6.80, you should replace the line Version=7.0.6by Version=6.80
